You can also easily format your Text document and "import text to template"
Simply format your scene how you want with the font style, and placement desired. Then in sequencer find the Scene in Scene Manager and right click and select the option "import Text to Template"
Format your text document with using a blank return between lines to tell Xpression to go find another text field, and if there is none, it will automatically use another scene.
Ex:
All the text for Scene 1 using 1 text fields
All the text for scene 2 using 1 text field
but with 2 lines
More text for Scene 3 and this can go on for a long time
Then if You have Xpression v4 or higher you save each song as it's own project and open the projects you need for band sets.
This is a great way to quickly import Song lyrics. I have done song lyrics in Inscriber and I think Xpression is much faster especially with the import text feature and multi-project support.
