I finally got the 6.1 update a few days ago and I think I got a good grasp of how to set them up by watching the videos on Xpression U.
I am having an issue right now with making it work in iNews. I made a couple of different .txt files that have been assigned to global lists for different templates.
Everything seems to work perfectly fine when I test the templates in Xpression. Once I published and tested those templates in iNews, the combo boxes are showing up but they aren't doing anything. I tried picking one and dropped it in the rundown but still nothing. Not sure what could be wrong... I thought it could be the path but if it was that, then it shouldn't be working in Xpression in the first place, right?
The file contains 2 columns:
Box Logo Box Logo Image
NBA S:\iNews Templates\Box Logos\NBA-BoxLogo.png
MLB S:\iNews Templates\Box Logos\MLB-BoxLogo.png
NFL S:\iNews Templates\Box Logos\NFLBoxLogo.png
etc.
Any ideas on what I could be doing wrong?
I did make other 2 templates with global lists via .txt files that do not have images. Both of the templates are working perfectly fine in Xpression but once I go to iNews only one of them works.
I would really appreciate the help. I think this feature would really help us out.
Thank you in advance.
