Hi Tue,
if your Scene Director has animation controllers that are positioned in such way that it runs for 346 frames. You can do two things:
- Move the animation controller closer to the start on the timeline
- Reduce the lenght of the animation controllers. That can be done by dragging the end of each animation controller towards left. Or set the total range in the bottom right of the screen to the desired duration.
/Niels
