I used to be able to have my rundown loaded through the Project Server that pulled graphics from all my published projects (Lowerthirds, Fullscreen, Slates) and also have any of my projects open at the same time so I could build graphic templates in between tapings. Now, when I try to open any project I get the messages below.
-Error opening project file D:/Projects/120 Sports 2016/New Fullscreens.xpf (Exception)
-Sorry, an error occurred while loading this project. A backup file exists, would you like to try loading it? After loading, you should save the file with a new name.
- Exception class: EAccessViolation
Access violation at address 006D7E72 in module 'Xpression.exe'. Write of address 0000000C
If I click yes on the window below, it just loads a 'recovered' version that's not true to my project. Not sure what changed, any ideas?
