  • 1.  Crawl in sequencer, trying to animate the text off
    Posted 12-31-2017 19:20
    I am working on a crawl using the sequencer instead of a Scene Group. In sequencer I have the background layer on FrameBuffer 2 Layer 0 and the text scenes in a group on FrameBuffer 2 Layer 1. I can trigger these on air, looks great.
    My issue is taking the scene offline. My background scene animates out as expected, but the crawling text scenes cut off air and it looks rough. I can't seem to get the text to animate off when I take the text scene group offline. I am very confident in scripting so I tried getting the text scenes and playing the outro scene director or animation controller, that didn't work. Then I tried the [I]Transition[/I] section for the text scenes within sequencer, setting that to dissolve off, but that didnt work. Also set the [I]Out[/I] transition logic on the template text scene to the desired scene director, nothing worked there. That's about everything I thought would work but here I am...
    Any other ideas for making this work?
    Thanks in advance.
    Mike
  • 2.  RE: Crawl in sequencer, trying to animate the text off
    Posted 01-09-2018 22:40
    Hello Mike,
    Maybe you can make a clean scene with a dissolve as a transition and set this scene on Framebuffer 2 layer 1.
