  • 1.  Transition Logic Bug?
    Posted 11-05-2015 17:07
    So I'm messing around with some transition logic again, and I know this is somewhat untrodden grounds here. But XPression Studio is kinda contradicting itself when I set this particular scene up. Here's what it's doing:
    I've got a video clip in the Scene Director for the "IN" and "OUT SD, and for the "OUT" SD, I have just reversed this video.
    Now, when I play the clip on the virtual server, it does exactly as it's supposed to. However, when I send it back to Framebuffer 1 and try to play it out from there, it doesn't work, as in it'll animate "IN" correctly, but for the "OUT" the video doesn't play backwards and just stays up until disappears at the end of the scene director. Any clue why it does this?
  • 2.  RE: Transition Logic Bug?
    Posted 11-05-2015 17:09
    Can you post the project?
  • 3.  RE: Transition Logic Bug?
  • 4.  RE: Transition Logic Bug?
    Posted 11-05-2015 19:55
    Thanks Phillip, looking into it..
