  • 1.  Sequence Group inheritance
    Posted 03-01-2017 18:58
    I'm trying to setup xpression for operators who are often in a time crunch and I'd like to make it as painless as possible. Is it possible to have clips added to a group in a sequence to inherit the server channel/frame buffer from the group?
  • 2.  RE: Sequence Group inheritance
    Posted 03-01-2017 19:07
    Unfortunately no :(
  • 3.  RE: Sequence Group inheritance
    Posted 03-01-2017 19:16
    Thanks for the quick reply! Unfortunate but, they'll survive :D
  • 4.  RE: Sequence Group inheritance
    Posted 03-02-2017 01:01
    When dragging items into the sequencer they will automatically be assigned to whichever server channel is currently the selected active channel. Double-click a different channel to activate it, and any items will then get that channel as their default channel when dragging to the sequencer.
    If you aren't aware, you can also bulk change the server channel of several items in the sequencer by selecting them all and using the take inspector to change them all at once.
  • 5.  RE: Sequence Group inheritance
    Posted 03-15-2017 21:35
    Thanks bford. I've actually instructed them to select an entire group and change the server channel that way. Thanks for the help!
