Hello all,
XPression version 7.0 should be released in July. It will be 32bit.
FBX import is under development and has a good chance of releasing with 7.1 in the months following the release of 7.0.
In regards to 64bit, what limitations or issues are you (the users) encountering in the XPression software that you believe will be corrected or improved by 64bit?
While 64bit will bring improvements with it, it seems to be becoming a trend in the industry that everyone assume (or desires) that 64bit will fix every challenge that exists in software. I know that other companies have released 64bit version of their software and it has been sometimes underwhelming,
I'd love to know what things our users hope 64bit will improve, so that if the things you want are not going to be effected by 64 bit, that we can make sure we look for other solutions, or even give you solutions that already exist today.
I'd also like to add that while XPression is a 32bit application that it is optimized for the 64bit Windows OS. XPression uses more memory, and uses it better, than a typical 32bit application will.
