  • 1.  Mask rolling credits
    Posted 09-08-2015 20:26
    Hey, another quick question - we have a credit roll and we want to mask it so that it only appears on the bottom third of the screen and doesn't take over the whole screen but it seems that masks do not affect the credit roll?
  • 2.  RE: Mask rolling credits
    Posted 09-21-2015 23:03
    You should be able to do it by making mask material on rectangle to cover up the text once it scrolls to a certain point. The Z position for the mask object must be higher than the z position for the scrolling text. Also, change the Render Order Priority for the text to "Normal" (instead of "Text On Top" default).
  • 3.  RE: Mask rolling credits
    Posted 09-22-2015 02:49
    Dominic, search for the forum post called "How do you Mask a Crawl" and you'll even find a sample project in there to show how to do it.
  • 4.  RE: Mask rolling credits
    Posted 10-17-2018 01:58
    The sample project is missing. Would you please repost it? Thanks very much!
  • 5.  RE: Mask rolling credits
    Posted 10-18-2018 08:49
    It's really easy to do that.
    On your scenegroup (because your mask don't have to move), put your mask to a Z-Position, like 1.
    On your children scene, put your text object at 0 (ZPos) and change its Render Order Priority to Normal.
    And voilÁ  !
  • 6.  RE: Mask rolling credits
    Posted 10-26-2018 18:52
    Just make sure not to use layer object for the masks or this will mess you up.
