  • 1.  Export Xpression Render from ENPS?
    Posted 03-22-2016 21:37
    Is there a way to export the rendered preview of Xpression plug-in from ENPS? For example, a producer in ENPS creates a graphic by using an Xpression scene template by inputting text. The graphic is needed for edit in a package. Can it be rendered out of ENPS somehow?
  • 2.  RE: Export Xpression Render from ENPS?
    Posted 03-24-2016 01:17
    I think the solution you want is to buy the Ross Video Xpression plug-in for your non-linear editing system...or just export it as video from your Xpression.
  • 3.  RE: Export Xpression Render from ENPS?
    Posted 03-24-2016 18:42
    It can't be rendered out of ENPS or the plugin but it can be rendered out of the XPression Studio.
    On your XPression Studio you'll have the MOS graphics in a group and you'll be able to find all the graphics that were made in the plugins.
    Right Click on the graphics you want to export (in the Sequencer) and select Export > Video or Images
  • 4.  RE: Export Xpression Render from ENPS?
    Posted 03-29-2016 00:42
    Thanks. Was looking for an easy solution to allow Producers to export graphics they make themselves to send to editors, but they don't have access to Xpression Studio.
  • 5.  RE: Export Xpression Render from ENPS?
    Posted 03-29-2016 17:07
    If you want to use the same XPression graphics in your story packages as you do on air you should look at using the XPression NLE workflow. Currently our NLE workflow supports Edius, Media Composer and Newscutter.
