  • 1.  XPression - Shot Clock Design
    Posted 08-27-2015 20:18
    Hey all,
    Is there a way to set up a text object to count down from a pre defined number in a scene? The idea is to create a shot clock effect.
  • 2.  RE: XPression - Shot Clock Design
    Posted 08-27-2015 20:33
    Yes, add a widget to your scene and set it to a Timer widget and you can edit the timer properties to start at a particular value.. In the datasource tab of the text object you can bind it to the widget.
  • 3.  RE: XPression - Shot Clock Design
    Posted 08-27-2015 20:34
    Fantastic. Thank you Brian!
