Ok, after asking the seemingly unanswerable earlier, I need to ask one that should be pretty simple to answer. How can I know what the frame rate / output resolution is for a project? One would expect to find that information under the Project->Properties menu, but alas no. I have had to convert some projects here and there, and for the most part have been saving them in separate folders so I that I could keep track of them, but before the holiday I was blowing and going and testing and am not sure now if I have the correct settings for the project I am in.
Soooo.. how can I know?
