  • 1.  viewing and scrubbing pre rendered animations in Main Viewport
    Posted 11-20-2016 10:23
    hi guys, i'm trying to take a pre rendered animation and add type to it...i know i can add it to a quad, but i won't be able to scrub thru it in the main viewport.
    i also heard you can drag materials into scene directors and they will play in the main viewport; but i have not been able to succeed with this....plus i've been turning off the autoplay and freeplay options....i can see the object in the scene director, but nothing appears in the viewport....
    what am i doing wrong?
  • 2.  RE: viewing and scrubbing pre rendered animations in Main Viewport
    Posted 11-20-2016 11:43
    Your pre-renderer animation is a material, bind it to a quad you already add to your scene (select the quad, double click on the material). Then drag and drop your material to a track of your scene director...
  • 3.  RE: viewing and scrubbing pre rendered animations in Main Viewport
    Posted 11-20-2016 12:03
    THANKS vinz, worked great....i wasn't adding anything, just thought it'd show up.....newbie.....
