We've tried to arrange a video play list in XPression Sequencer. Normally, we see the timecode count down of the clip item during the clip is playing.
However, when we assign the In/Out effect to the clips, the timecode count down will pause itself. For example, if I set In effect for 13 frames, the timecode will pasue after clip played for 10 frames. But actually, the clip is still playing in the server channel. Please find the attached video link for your reference.
The timecode count down will only works normally in the sequencer when the In/Out effect set as CUT(0).
We are using XPression Studio v6.5_3600.
Is it not recommended to set In/Out effect to the clips?
Please advise.
Tony
