I have been trying to figure something out for a while and havent had much luck. I want to right justify and word wrap some text. I go to Tabs, set number 1 to Right. Thats great. Justified.
Next I set word wrap to 800, for example. It doesnt word wrap, just continues writing one long line. Also, the bounding box slides off to the right side, which is not the behavior I would expect since the text is effectively typing to the left.
Anyone have an idea? Left justify works fine, as does center. I can't get a right justified and word wrap to work for some text that needs to line up on the right. Using v6.1. Thanks in advance.
Mke
