  • 1.  After Effect projects
    Posted 03-22-2019 18:44
    Does XPression takes in AE files directly? Or do I need to render .movs and then import it into my scene?
  • 2.  RE: After Effect projects
    Posted 03-25-2019 11:27
    You will need to do render to video or image sequence. However, we recommend using our codec which you can do via XPression Video Coder (installed along with XPression) or if you have AE on PC you can install our codec directly. We also have an automated software called INcoder but this is an optional extra but is great if you are planning on doing a lot of video conversion regularly.
