  • 1.  Graphic animation timing
    Posted 11-30-2017 19:07
    When I play an animated graphic from xpression it brings in a early simulation of the animation just as solid black silhouette shape of the graphic before the graphic comes in. It's hard to explain but has something like this happen to anyone? I tried fixing the timing offset in xpression but it didn't work.
  • 2.  RE: Graphic animation timing
    Posted 11-30-2017 21:31
    Sounds like your fill and key signals are out of time, and the key signal is ahead of the fill.
    Can you view both the key and fill in your multi viewer at the same time and see if one is ahead of the other?
