I am generating a timer (hh:mm:ss) from time specified in hundreths. By using math in Visual Logic I get the correct time elements, and then use the Concentrate block to gather the numbers in order. If there is less than 10 minutes or seconds it displays with only the one digit: 16:8:26. Is there a way to force the block to display two digits? With strings I found many ways to control the number of digits after the comma, but I could not figure out a way for it to go the other way.
This is what I found on the forum: http://goo.gl/uoOpJD
I have also included the Visual Logic setup i have.
Thank you in advance!
Oda
