  • 1.  Dashboard for XPression Clips
    Posted 01-24-2017 07:17
    Hi, is it possible to create a custompanel to display 1 or 2 server channels + clip list on the dashboard where we could drag and drop clips to be played on either channel? Many thanks.
  • 2.  RE: Dashboard for XPression Clips
    Posted 01-25-2017 00:25
    You might want to ask this in the dashboard forum as well. I believe there is an option for dashboard which is a VDCP interface which can be used to load/cue clips into the XPression server channels. This may be a paid option in dashboard. I do not know if it can be used with custom panels.
  • 3.  RE: Dashboard for XPression Clips
    Posted 01-25-2017 08:57
    Thanks bford, we got it working using the Blackstorm template.
