I want to dissolve out of a video clip.
I added video material (duration 344 frames) to a quad. Dragged same video to scene director with 200 frame animation controller. Set an alpha keyframe 100% at beginning of dissolve and another at 0% at end of dissolve. Scrubbing along timeline in key graph editor dissolve happens as expected, but when playing through sequence, video plays to end and stops.
I have tried this with animation controller starting at position zero and alternately with it overlapping the range of the dissolve.
I also a take offline event, but it cut off even with scene take item transition set to dissolve.
I could back up and render video with the dissolve built in, but there would be instances where that would be a problem.
