  • 1.  Preview output doesn't follow
    Posted 07-06-2017 15:59
    Hi
    I am working on client's system with a Corvid88 card, and running v6.7 3769 (we need the improved movie playback handling, UTF character handling and global scripting) and have the 3rd Corvid output set to preview channel 1, but the preview output doesn't always follow. The preview window in the Sequencer is fine, it's just the SDI output that doesn't always change, unless I change something in the take item - which I won't need to do as I have set up the graphics stack already.
    Any ideas please?
    Simon
  • 2.  RE: Preview output doesn't follow
    Posted 07-06-2017 16:18
    Do you have it setup as an Upnext or Channel Preview?
    Simon, as a freelancer please make sure a clients XPression system is in software warranty before upgrading. We can't support beta versions at sites out of warranty.
    Don't know who your client is, just making sure you know!
  • 3.  RE: Preview output doesn't follow
    Posted 07-06-2017 17:16
    We are only working with a single channel output, so previewing the channel is what I need. I tried Up Next as well, as that is effectively the same thing, but that exhibits the same behaviour, in that the picture only changes if I make a manual update to a published item.
