Hi there,
I have an HTML page, where admin users set data to be displayed in lower third template over the video. Data is changed on run time and not saved any where. I need to show this data on lower third template in Xpression.
I can send the data over TCP/UDP easily and If using Node.JS /Javascript API is helpful i can use that.
So any ideas or suggestions on this please.
Thanks.
