I am trying to use Visual Logic to adjust the body of the text on a fullscreen depending on whether there is a subtitle and or headers. Here is an example of how it looks...
If there is no subtitle, I want the "Header for column" and the bullet points to have a higher Y axis. Likewise, if there is no "header for column" I want the bullet points to be higher has well and the combination of the 2. For example, if there is a "Subtitle, but no "Header" I want the bullet points to have a Y axis like this...
And if there is no Subtitle or Header, I want the bullet points to look like this...
Also, if there is a way to spread the text out using Visual Logic, that would be a great help as well. Thank you in advance for anyone's help with this if possible.
