  • 1.  Background Videoclip play from the beginning in loop mode after Transition Out
    Posted 08-20-2018 14:18
    Hi!
    I couldn't manage to play background Video (in loop mode) from the beginning after other scene with Out Transition effect in cut mode (without take offline).
    The new scene start the Auto Start (of background video which is in Loop Mode with Auto Start and Free Running ) without "Wait for out effect"; the background and other elements from Scene director are not in sync anymore.
    As a second issue if the previous scene doesn't have a Out transition a short "glitch" (the null scene) is displayed for one frame.
  • 2.  RE: Background Videoclip play from the beginning in loop mode after Transition Out
    Posted 08-21-2018 17:14
    The "free running" option is used to indicate that a video should not restart when going between two scenes using the same video.
  • 3.  RE: Background Videoclip play from the beginning in loop mode after Transition Out
    Posted 08-22-2018 07:22
    Yes, it's OK, I want this because I want to use B2B.
    My issues are:
    - the Video start to play when the previous scene is taking the transition out (using other scene / other video) instead of start to play when the first scene start to play.
    - If the new scene has Intro scene and it cut the current scene (only background video without any intro/outro B2B scene) the "NULL" scene is diplayed for one frame (no text, but the middle frame of looped background).
    I'm using XPression Studio SCE v8.0 build4089
  • 4.  RE: Background Videoclip play from the beginning in loop mode after Transition Out
    Posted 11-06-2018 14:21
    Hmm... No answer.
    Maybe the video and file project example it will help to understand my issue.
    Project file: http://s.go.ro/clebqbxm
    In the video I'm playing (on auto mode - 10 sec. for every item) scene 1 and 2 with transition logic for Transition In, Transition Out and back to back.
    Main issue:
    1. "NULL" scene is diplayed for one frame (no text, but the middle frame of looped background) if the scene has an intro in transition logic.
    2. If the Transition In is comming after one Transition Out, the background video start is advance and the video clip and scene elements are not in sync anymore.
    3. Time to time the loop (in this case should be a still) is not frame accure and display some frames around the value frame and the background is jumping around.
    https://www.youtube.com/watch?v=W_7qoShGniA&feature=youtu.be
  • 5.  RE: Background Videoclip play from the beginning in loop mode after Transition Out
    Posted 11-06-2018 16:33
    Hello there,
    im having the same issue with videos running in free running, when we hit take, a random frame of the video is shown. We spoke with techsupport and they could recreate this issue in the lab,
    but we dont have any answers for this problem yet.
    Regards
    Diego
  • 6.  RE: Background Videoclip play from the beginning in loop mode after Transition Out
    Posted 11-06-2018 16:50
    Hi Diego,
    I've contacted your Tech Support rep for this case and they should reach out to you with a fix soon. Let me know otherwise.
    Garner
    gor - we are checking your project today, thanks for providing it.
  • 7.  RE: Background Videoclip play from the beginning in loop mode after Transition Out
    Posted 11-06-2018 17:03
    Thanks Garner!
    Diego
  • 8.  RE: Background Videoclip play from the beginning in loop mode after Transition Out
    Posted 11-06-2018 19:06
    Hi Gor,
    Our XPression Project Specialist took a look at your project and had the following feedback:
    [LIST=1]
  • Instead of having your Lower Thirds 1 In Transition videos "auto start" and "free running", I would keep those check boxes blank and I would consider putting the videos on the "Transition In" Scene Director . This will avoid the interference with the Transition Out Scene Director.
  • [LIST=1]
  • Make sure you set the default frame marker in the Transition In Scene Director to a point where the lower third is fully transitioned in. When you go back to back between Scenes the new Scene coming online goes to the default frame marker set in the Scene Director.
  • #XPression
  • 9.  RE: Background Videoclip play from the beginning in loop mode after Transition Out
    Posted 11-06-2018 19:35
    1. Yes, I know I can put the clip in Scene Direct and to have a frame accure playback, but this is true only when the intro video is ending in still, if you have a nice loop you should use "Auto start" and "Free running". In my exemple I used a lower third without any continous loop animation just to see the issue and if you are playing around - manual take items from playlist, is easy to see my nr.3 issue - looping points are not accure.
    2. Yes, as you can see, my Default frame is set at the end of first Transition In scene. I don't know why is displayed in the first frame...
  • 10.  RE: Background Videoclip play from the beginning in loop mode after Transition Out
    Posted 11-08-2018 05:54
    Please let me know if you can reprodece the issues discribed.
