Yeah.. I group node thing might be a cool way to handle it, although probably more difficult to execute from a development standpoint. I was honestly just thinking about having the paths connected to a selected node going yellow with the connect nodes getting a yellow outline. They already go gray if logic is copied and there is a node missing in the destination, so I figure the framework is already there.
I hear you on the scripting thing, Mal, and it is still something I want to learn, but I will say that with VL, results are immediate and much easier to trouble shoot. Now what WOULD be cool is a VL compiler, so that one could use VL to build something best suited for a script, and then convert the VL directly into a script, having it apply directly to the objects necessary. There'd still be a need to write script to deal with situations and parameters which VL can't, but for the vast majority of areas for which there is overlap, a VL compiler would be a godsend, best of both worlds kind of situation.
