  • 1.  XPression - Z-Axis Bug
    Posted 07-22-2014 14:42
    Hey all,
    Yet another forum post, but its rather serious, every time I'm opening XPression Designer now, nearly all of my graphics have a problem when I reopen my project files. Whenever I open up any project, certain assets change their position on the Z-Axis and move forward just a few points. Additionally, after I fix all of the Z positions that have changed, I even lock those layers, save again, close for the night, reopen in the morning and they have still changed again. Any help or fixes for this issue would be most appreciated.
  • 2.  RE: XPression - Z-Axis Bug
    Posted 07-22-2014 14:57
    What version and build of XPression are you running?
    If this issue is urgent you should contact techsupport@rossvideo.com. The Ross Community is not monitored by the support team and is not used as a technical support tool.
  • 3.  RE: XPression - Z-Axis Bug
    Posted 07-22-2014 20:44
    The most current version. Any suggestions are helpful.
  • 4.  RE: XPression - Z-Axis Bug
    Posted 07-23-2014 14:05
    There are multiple current versions of XPression. Can you please specify the version and build number?
  • 5.  RE: XPression - Z-Axis Bug
    Posted 07-23-2014 18:25
    Are the actual numbers in the Z transform spin box changing, or are you just seeing the objects appear in a different place in the viewport? How much do they change by?
