Does it have to be the next item in the sequencer? Or can it be a static take item in the sequencer?
If you want to trigger a static take item # then yes it would be possible.,
If you want it to be the next item in the list of the trigger scene that is harder.
Hmmm...maybe if we use the keyboard take next shortcut...
Possibly you could have the scene director event trigger "take next" in the sequencer - so it would take the highlighted item and move down again. Only way to do that is to have the scene director event send a RossTalk Take Next message back into the XPression, might not be super frame accurate though.
