Thanks- yes, Ross Tech Support helped me figure out the ASCII data capture. It was a bit of a manual process figuring out the fields, start byte, length and that sort of thing, but I'm happy to share the scripts and datalinqs. Once they got that figured out, it worked pretty well. We had a bit of a display issue every now and then where results would display funny, but then fix themselves. That was entirely due to lack of time to really test and configure it. The race was Saturday morning, we got results working the Friday night before at 7pm, so we went with it. I would recommend doing a bit more testing before hand :-) I tried zipping and uploading what I show as the latest versions, try those & let me know.
We had to enable data logger in the ascii datalinq setup to see what we were getting from the timing & scoring feed, and eventually were able to figure out how to capture the data.
Thanks, hope that helps!
-Jay
Jay Cofield
University of Montevallo- Dept of Comm
Sent: 04-30-2024 14:52
Subject: FinishLynx and Xpression
Hi Jay, We are looking at covering an event that uses this system and they display using Relustv. How did you make out with this? Are you able to share anydetails?
Kaushal Hathi
EAST LINK AP
Sent: 10-19-2022 12:14
We're supposed to stream our conference XC championships in about 3 weeks, did you happen to get a copy of this script that I can use? Or any advice? Thanks!
Jay Cofield
Sent: 04-07-2018 16:18
I'd be interested in knowing how this was configured; and getting a copy of the LSS script being used on the finishlynx system if they are willing to share it.
