  • 1.  Loop
    Posted 06-16-2015 00:51
    What is wrong in rhis loop?
    dim objRedBlue as xpTextObject
    dim objBkg as xpBaseObject
    dim objMat as xpMaterial
    dim i as Integer
    for i = 1 to 6
    Self.GetObjectByName("Kreds_bkg" & i, objBkg)
    Self.GetObjectByName("Kreds_farve" & i, objRedBlue)
    if objRedBlue.text = "B" then
    Engine.GetMaterialByName("Blue", objMat)
    else if objRedBlue.text = "R" then
    Engine.GetMaterialByName("Red", objMat)
    end if
    objBkg.SetMaterial(0, objMat)
    next i
    When I put this in 6 times, everything works:
    dim i as Integer
    Self.GetObjectByName("Kreds_bkg 1", objBkg)
    Self.GetObjectByName("Kreds_farve 1", objRedBlue)
    end if
  • 2.  RE: Loop
    Posted 06-16-2015 01:09
    It probably can't find the objects, so it will exit when you try to access objBkg because it is null.. Make sure you turn on the debug monitor for scripting option so you can see the error messages it returns.
    In the loop code you provided, it is looking for an object called "Kreds_bkg1" (no space), and in your example without the loop it is looking for "Kres_bkg 1" (with a space).
  • 3.  RE: Loop
    Posted 06-17-2015 00:40
    In both these lines, I had to add a space
    The code now looks like this (and works!):
    dim i as Integer
    for i = 1 to 6
    Self.GetObjectByName("Kreds_bkg " & i, objBkg)
    Self.GetObjectByName("Kreds_farve " & i, objRedBlue)
    end if
    next i
