  • 1.  animated reveal possible?
    Posted 04-07-2015 13:19
    Looking to have a scene that is created animate "OPEN" as in let's say a vertical/diagonal wipe type pattern, to reveal the LIVE video feed as in opens.
    Can this be done in Xpression like in most other compositing software using a matte source?
    Or some other way?
    Thank you.
  • 2.  RE: animated reveal possible?
    Posted 04-07-2015 15:17
    That can definitely be done using a mask.
    also, not sure what version software you have but in ver 5.9 you could use a wipe effect on the quad to reveal it. Just drag the Linear Wipe to your quad's Object Track. Then change the properties to get your wipe.
  • 3.  RE: animated reveal possible?
    Posted 04-07-2015 15:20
    Steve,
    On version 5.7.
    We have 2 Design ONLY seats and ONE Studio Seat.
    Anthony
  • 4.  RE: animated reveal possible?
    Posted 04-07-2015 15:51
    I'm pretty sure 5.7 has the same effects. From the layout side select effects from the fly-out menus on the right side of the screen.
