  • 1.  Xpression 6.1 Using Video Inputs 1 and 2 as Split Key...
    Posted 02-11-2016 17:42
    Sorry to revisit this topic (I think I did a bit over a year ago but I lost the notes) but I cannot solve this simple puzzle.
    I want to use 2 video inputs to create a keyed element within Xpression.
    I know it can be done, I have used it many times before but deleted the projects because I went in a different direction.
    Video Input-1 has a video signal and video input-2 has it's key signal. i need to use those 2 materials mapped to a single quad to use as a keyable element within my scenes.
    The magic sauce lives in understanding the relationships between material attributes such as "Previous Stage" and "Current stage" Alpha blending, etc.
    Is it me that I cannot find practical usage examples of these attributes or is it that they don't exist?
    Any guidance would be appreciated.
    Thank you ROSS
  • 2.  RE: Xpression 6.1 Using Video Inputs 1 and 2 as Split Key...
    Posted 02-11-2016 19:24
    In recent versions of XPression you can enable an option in the Input 2 settings of the hardware setup to indicate Input 2 is an alpha for Input 1. Then you can just use a normal live source material with Input 1 as normal and it will have the alpha automatically applied to it. This is much more efficient as the video/alpha are combined at the hardware level and it is impossible to have a frame drift between them.
  • 3.  RE: Xpression 6.1 Using Video Inputs 1 and 2 as Split Key...
    Posted 02-12-2016 16:56
    Thank you B. for that solution - it works quite efficiently but... I dont necessarily want my video inputs to always work as a key pair.
    I could have several xpression scenes that use two distinct video feeds in NON PAIRED MODE.
    I assume I require a script to enable and disable the hardware keying on a per scene basis?
    Thank you again
