Hi Brian
Trying to get an ADODB datalinq to work with Excel after watching the tutorial you mention.
Everything appears to be the same except the Datalinq Server configuration is different as mentioned below the video. The "test connection" comes back with a "Connection successfully established" message.
When I try to Browse the spreadsheet it comes up blank and there is no dropdown menu of tables as shown in the video.
I have tried experimenting with a previous spreadsheet of data as well as creating a new simple 3 column worksheet but still the same result. No data or table dropdown.
Using Designer v5.5 build 2731 and Excel 2010
