I have made a global list in which I also want to apply a color or color material to a shape based on which item is chosen in my list. The shape is published - the colums are assigned and when I chose it in the sequencer it fills in the material name or the color code but it does not apply it. Like when you chose it manually you have to click on the material.is it possible to apply material with user input controls? with pathes of pictures or the name of pictures it worked fine so I thought it works also for a color as a material.
