  • 1.  Visual Logic do not have "if-then-else" process
    Posted 12-05-2017 15:18
    In Visual Logic interface, I cannot find the if-then-else process. If I need to work out this process, what can I do?
    For Example, I live data from Datalinq, if the value=A, then then object will move up 900 pixels, else, object will move down 400 pixels.
    I cannot find a way to work it out with existing logic processes? Please advise.
  • 2.  RE: Visual Logic do not have "if-then-else" process
    Posted 12-05-2017 20:11
    You can use something like this:
    (oops just realized in my picture the "400" value is not fed into the input selector block; but it should be..)
  • 3.  RE: Visual Logic do not have "if-then-else" process
    Posted 05-15-2019 06:33
    Hello Brain Can you post it one more time coz you image is not showing in you image file ....... it will help me lot
