  • 1.  Transition Logic, don't work sometimes. And more mistakes.
    Posted 10-24-2017 18:54
    Hi.
    I have a project XP. Version 7.0 build 3798.
    I am created few rules for Transition Logic. And when I open project and check my scenes - Transition Logic sometimes don't work. But if I reanabled any rule - TL will work.
    And one more moment. When I created new rule and select need SD in B2B or on another tab, then change SD in past created rules. When I select another scene and back in same scene - I see necessary sd in self places.
    I need created many rules and I don't sure what they wil be good worked.
    I work in Win 10 - 64. Bug in new version maybe. (
    Thanks.
    And on sound. Have in XPression opportunity publish sound in new version?
    Thanks, thanks, thanks.
  • 2.  RE: Transition Logic, don't work sometimes. And more mistakes.
    Posted 10-24-2017 18:57
    May are Your give me manual file for TL? I do not all understand in that. Please.
  • 3.  RE: Transition Logic, don't work sometimes. And more mistakes.
    Posted 10-24-2017 21:06
    The issue with changing a scene director causing other rules scene directors to change was resolved in 7.0 build 3803.
    You should contact Tech Support and request an upgrade to that version.
  • 4.  RE: Transition Logic, don't work sometimes. And more mistakes.
    Posted 10-25-2017 00:13
    Thanks for quick answer. But I no have support on my work key. Ended in February 2017. I will be try ask in our local Tech Support. (
  • 5.  RE: Transition Logic, don't work sometimes. And more mistakes.
    Posted 10-25-2017 00:23
    What about manual for Transition Logic? I maybe try get file special for TL? Thanks.
