  • 1.  iNews - Output Workflow
    Posted 04-20-2016 23:08
    We recently changed our workflow, we used to use 2 different control rooms to run our live shows. Now, we only use the one control room so we've been trying to incorporate the extra Xpression computer we have into our workflow.
    We are trying to use the 4 outputs we are getting from the two computers. Right now, we have to load 2 separate rundowns through Ross Mos so we can load the graphics through the right outputs. Is there a way we can adjust iNews in some way to send graphics to the 4 different outputs? Meaning, from one rundown all graphics would be loaded where they need to go?
    No clue if this is possible but just thought I would ask.
    Thanks in advance, hopefully that made sense.
    Mildred
  • 2.  RE: iNews - Output Workflow
    Posted 04-21-2016 12:41
    Yes definitely it is possible to have one rundown send to all four channels. There might be a lot of config changes necessary depending on how your system is currently configured so it's impossible to tell you through the forums what might need to be changed. The best approach would be to contact tech support and have them assist you.
    The Ross Mos gateway would need four virtual channels configured in it; each points to a physical channel on the two different XPressions; and the Remote Sequencer (if you use it) might need some adjustments to the connection groups. There shouldn't be too much to change on the iNews side of things.
