  • 1.  word wrap behaving funny
    Posted 05-15-2014 21:10
    My word wrap doesn't work very well. The lines are way off. Some lines look right and then other are too short. There doesn't seem to be any rhyme or reason to it. Has anybody else experienced this? Is there something I can do or something I am missing to make this work properly? I appreciate any help.
    Mike
  • 2.  RE: word wrap behaving funny
    Posted 05-16-2014 15:14
    What version and build number of XPression are you running?
    Can you upload a copy of your project that is having the word wrap issue?
  • 3.  RE: word wrap behaving funny
    Posted 05-16-2014 15:20
    version 4.0 build 2025
    Here is a download link to my project, it is in the "POLITICAL FP" scene.
    https://www.dropbox.com/s/79cotoghzs6rdr8/BASE031.xpp
    It actually does this with every word wrap I have.
    Thank you.
  • 4.  RE: word wrap behaving funny
    Posted 05-18-2014 19:35
    It's caused by the script you have in OnOnline and OnPreviewRender that is converting the text from all lower case to all upper case (it is probably wordwrapping based on the lower case widths, then the script changes it to upper). If you remove that script it starts working correctly. If you want all upper case then you can set the "Sml Caps" property of the font to 100% and anything you type will be converted to upper case automatically.
  • 5.  RE: word wrap behaving funny
    Posted 05-19-2014 12:40
    Awesome, thanks Brian! :)
