  • 1.  Can I publish font size or Used Fonts?
    Posted 06-06-2014 04:23
    I see text, scale, position, etc. in the Template Links panel, but what if I want to change fonts at the Sequencer level? I'm not seeing a way to do that. Any ideas?
    sf
  • 2.  RE: Can I publish font size or Used Fonts?
    Posted 06-06-2014 12:43
    You can't "publish" it per-say, but you can add font tags to the text in the template data.
    A font tag can either be the name of the font, or the font number, enclosed in { } braces.
    e.g. {1}This will use font 1.. {RedFont} This will use the font called RedFont.
    This allows you to mix and match multiple fonts within the same text object.
    There is also a button (looks like two little A's) above the template data, that shows you the fonts and will insert the font tag for you.
