  • 1.  Scene In transition in front
    Posted 10-29-2018 01:02
    I've built two scenes, both with a transition in and transition out scene director. I set up transition logic for both scenes, to ensure that each scene followed the In/Out scene directors. I put both scenes in the sequencer, and when I transition from the online scene to the other (currently offline) scene, the online scene transitions out, revealing the incoming scene. Is there a method for ensuring that the incoming scene transitions in front of or on top of the currently online scene, leaving the online scene to transition out behind the incoming scene? I hope this makes sense.
  • 2.  RE: Scene In transition in front
    Posted 10-30-2018 14:29
    Can't you just put the in-coming scene on a higher layer? Or you want them on the same layer so triggering the new one will take the old one off automatically?
  • 3.  RE: Scene In transition in front
    Posted 10-30-2018 18:52
    If they need to be on the same layer, I think you need to generate Back to Back rules in the transitionl logic. The Back 2 Back rule allows you to choose which scene should be rendered on top (the incoming or the outgoing).
  • 4.  RE: Scene In transition in front
    Posted 11-01-2018 02:59
    Thanks, guys! It was a B2B condition that was needed. I thought I had set that up correctly, but taking a step back made the difference.
