Yes, it is possible. It might take a bit of fiddling, but you can use the string nodes for that. You can select different parts of strings (left, middle, right) and concatenate. I don't have visual logic in front of me to give you specifics, but you'll find it all in the Strings section in the right-hand sidebar.
James.
