  • 1.  Replacing Text Color in Templates
    Posted 06-22-2015 16:40
    Hello All,
    We have this new graphic where we would like to have 5 different color options on text depending on the golfer's score. Right now, we made our graphic like we normally would and created a text template with the different color for each hole (18 holes plus 5 different color options). Is there an easier way of doing this? Through visual logic maybe? Our graphics are filled out through iNews.
    I would really appreciate the help.
    Best,
    Mildred O.
  • 2.  RE: Replacing Text Color in Templates
    Posted 06-22-2015 16:53
    Text with font tags would be the easiest way to handle this. I'll assume you have a font for -2 or lower, -1, par, +1, and +2 or higher. Get the font numbers for each of these, and you can add it in line to change the font following it. For example, if your par text is font item 1, you would enter `{1}0` or `{1}par` into the text object.
    Visual logic should be able to handle it, but I'm not the guy to answer for that. Someone else could probably chime in to help.
    Scripting, on the other hand, I can help you with. Keeping the same assumptions as earlier, you could script it to find the value, then change the font accordingly:
    FOR FUTURE READERS, I HAVE EDITED THE SCRIPT TO INCLUDE REMARKS
    `dim score as xpTextObject
    dim temp as String=nothing
    dim scoreval as Integer
    dim bogey as xpFont
    dim birdie as xpFont
    dim par as xpFont
    dim dbog as xpFont
    dim dbird as xpFont
    'assign the text object and create an integer from it
    Self.GetObjectByName("Score Text Object", score)
    scoreval=Cint(score.Text)
    'get the fonts from the engine
    Engine.GetFontByName("Bogey Font", bogey)
    Engine.GetFontByName("Birdie Font", birdie)
    Engine.GetFontByName("Par Font", par)
    Engine.GetFontByName("Double Bogey Font", dbog)
    Engine.GetFontByName("Double Birdie Font", dbird)
    'this is the part that does the work
    'each if/elseif statement checks the value of the score
    'then it moves the text to a temporary string
    'deletes the original text
    'changes the font
    'and copies the text back in with the new font applied
    'if you do not delete the old text, the font will not update
    if scoreval = -1 then
    temp=score.Text
    score.Text=""
    score.CurrentFont=bogey
    score.Text=temp
    elseif scoreval = 1 then
    temp=score.Text
    score.Text=""
    score.CurrentFont=birdie
    score.Text=temp
    elseif scoreval = 0 then
    temp=score.Text
    score.Text=""
    score.CurrentFont=par
    score.Text=temp
    elseif scoreval < -1 then
    temp=score.Text
    score.Text=""
    score.CurrentFont=dbog
    score.Text=temp
    elseif scoreval > 1 then
    temp=score.Text
    score.Text=""
    score.CurrentFont=dbird
    score.Text=temp
    end if`
  • 3.  RE: Replacing Text Color in Templates
    Posted 06-22-2015 18:19
    Just to expand on Dan's suggestion.. Note that when you use the font tags, you can use the Name of the font in the tag instead of just the font message. E.g. {par}0 {birdie}-1 {bogey}+2 etc... (assuming the fonts are called par, birdie, and bogey)
  • 4.  RE: Replacing Text Color in Templates
    Posted 06-22-2015 18:36
    It worked perfect! Thanks for the help to both of you :)
