  • 1.  How user input control combo box - Datalinq combination works?
    Posted 05-09-2017 15:23
    In this tutorial for creating radio button,combo box etc.. I didn't understand how it could be when just one text object linked excel with datalinq but when changed in combo box also second text object alsoi changed.Second text not link anywhere! How it happened.
    https://www.youtube.com/watch?v=pkACfzHp4rE
    Thanks.
  • 2.  RE: How user input control combo box - Datalinq combination works?
    Posted 05-09-2017 15:27
    The second text object is set as a User Input Control Combobox with Datalinq as the source at 11:33.
  • 3.  RE: How user input control combo box - Datalinq combination works?
    Posted 05-09-2017 16:04
    Hi Garner,
    for second text I mean email section.He never touch email text or I missed.He just set up name combo box link to excel with datalinq.That's all. Where I missed?
  • 4.  RE: How user input control combo box - Datalinq combination works?
    Posted 05-16-2017 15:43
    You have to route the email column to the email text field. Use 'Assign Columns' tab to do this.
    So go to the name node, set up the user input controls for DL, then assign columns within the name node. This will populate the email node with the email column based on the name you select. Do not go to the email node to do this, or you will lose the function to populate based on the name.
  • 5.  RE: How user input control combo box - Datalinq combination works?
    Posted 05-22-2017 20:53
  • 6.  RE: How user input control combo box - Datalinq combination works?
    Posted 12-02-2018 10:20
    hello MiaSanMia, i got this how to do with text but iam suffering from changing headshot according to this name combo box. i want to change headshot according to name combo box? can you explain it please
  • 7.  RE: How user input control combo box - Datalinq combination works?
    Posted 12-10-2018 08:37
    thank you. i got it now :)
