So you could chose to setup RossLinq Connections to Channels 3 and 4 of the Solo. Then you send the Full Screen Graphics to 3 and 4. That will get you fill only.
You can also send to say Channel 1 first then send to Channel 3 to get 2 full screen fills.
On your comment about the Clip Player and a MS FS -- Use Channel 3 or Channel 4 for the Media Store. Then send GFX to Channel 1(if using 3) or 2 (if using 4). The clip player will run fine and now you won't have an alpha channel for that Media Store.
"‹Les
