If you intend to use Auto Squezee the function work well but just using Left Alignment.
If your text is larger than Max Width specified in Tab & Option tab and text si Left Aligned, the text is squezzed well and fit into. If the text is Center or Right Aligned the text is squezzed too but it will be shifted in left side more and more if the text is longer.
How can we fix this?
