Hi Tech Director,
Just a question, where did you see that it doesn't dissolve out? Were you looking on the fill output or were you actually keying it over an image?
Because when your keying mode is set to unshaped, the fill-image will actually cut in between dissolves. So on the fill-monitor you would not see any dissolve. However, on your key-output, you would see the key dissolve.
So could you check if the dissolves are not working when the graphic is keyed over another image (camera, VT or something)
Best regards,
Kenneth
