  • 1.  Visual Logic not working properly
    Posted 11-13-2018 12:07
    Hi!
    Can somebody please explain to me why this is returning a value of 0?
  • 2.  RE: Visual Logic not working properly
    Posted 11-13-2018 16:04
    Which version of XPression are you running?
  • 3.  RE: Visual Logic not working properly
    Posted 11-13-2018 16:41
    I am currently using Xpression GO! V6.5
  • 4.  RE: Visual Logic not working properly
    Posted 11-13-2018 16:58
    On the Layout side, there is a blue diamond that shows continuous animations and other effects. If this is not active, the visual logic will not run and the value will come up as 0. If it is active, you will get the correct values.
