  • 1.  Publishing a graphic with a widget
    Posted 09-05-2018 11:15
    I published a fullscreen with a clock/timer widget to automatically display the current date. However, when I look at it in Inception, and load the playlist, the widget does not hold, and displays the date that I published it. Any thoughts?
  • 2.  RE: Publishing a graphic with a widget
    Posted 09-05-2018 14:05
    Unpublish the text object that is assigned the widget.
    Because the text object is published it is being assigned a value by the MOS workflow.
  • 3.  RE: Publishing a graphic with a widget
    Posted 09-06-2018 11:08
    Works great! Thank you!
