  • 1.  Pause events in In/Out transitions?
    Posted 07-26-2018 18:29
    I've created a full screen graphic with a sponsored slate at the beginning of an in transition, which reveals tweets. I've built in basic transition logic to flip between tweets datalinq'ed with Inception in different takeID items. Then I have an out transition that closes to the same sponsor slate. Is there any way to have a pause event stop the in and out transitions at the first and last frames, respectively, so that it will hold on the sponsor slate until I am ready to reveal the first tweet, and keep the slate online at the end of the out transition?
  • 2.  RE: Pause events in In/Out transitions?
    Posted 07-27-2018 16:48
    If you build the IN and OUT transition using animation controllers then you can place a pause event on the scene director that corresponds to those animations. I don't know that you can do it if using the IN and OUT in the Take Item. Transition logic comes into play as well.
  • 3.  RE: Pause events in In/Out transitions?
    Posted 07-29-2018 16:23
    I have had an issue like that before. I found that in my main animation the pause was ignored if a different scene director was playing later in time than the pause occurred. It basically made xpression jump past the pause.
