  • 1.  turn page effect
    Posted 04-04-2014 19:58
    hi, as the title say... is there a way to do a turn page effect?
  • 2.  RE: turn page effect
    Posted 04-05-2014 16:38
    from the "Take Item" tab you can set all different kinds of Transitions for the template.
  • 3.  RE: turn page effect
    Posted 02-19-2018 23:40
    I'm new at Xpression and finding there's lots to learn. I also need a 'page turning" effect -- like the paper curling up and over to reveal the next graphic. The Transitions tabs don't have anything like this effect as far as I can tell. I can certainly rotate a page off the screen, but it's flat and not exactly the look I need. Any help/advice would be appreciated Thanks.
  • 4.  RE: turn page effect
    Posted 02-20-2018 19:18
    I would build this out elsewhere like AE, or even a DCC like C4D if you want more dimensionality and render it out as a video to be used as a texture in XPression, set it to play at a continue point and animate masks in XPression to complete the illusion
