  • 1.  TABLE gfx creation
    Posted 05-19-2015 16:00
    Here's an interesting question....
    A couple points first.
    A) We have an Excel file that we'll use as the database.
    B) I'm looking to make a TABLE... similar to a table that you'd make in PowerPoint. Set it up with let's say 6 columns and 8 rows. This now creates 'cells'.
    Questions are:
    1) Can XP make a TABLE like this where text can be typed in each cell? Without manually making a series of 48 text boxes stacked and lined up next to each other.
    2) Can I then assign the data from the corresponding Excel file to each of these cells? Without doing them one at a time to a text box.
    Any help or knowledge in this would be great.
    Thanks.
    Anthony
  • 2.  RE: TABLE gfx creation
    Posted 05-19-2015 17:00
    There is no way of building a table in XPression that is equivalent to how it would be done in a Microsoft Office product.
    As Dan mentioned in the other thread, you'll have to use Visual Logic to position the objects that make up your table rows/columns based on whatever attributes you need (# of text objects, size of text objects, etc...)
    You will have to create a text object for any cell you want to display text from. You can duplicate your text objects and then use the increment rows to expedite this.
    [IMG]http://i.imgur.com/Wd3jRgs.png
    [/IMG]
